How can I generate a 3D image that is crisper on the edges?
Within the rendered 3D image, select the Options > Render Options. Place a checkmark next to Anti Alias,
which will allow for the adjustment of the slider bar. The higher the value being used, the clearer the image will
be on the next regeneration. It should also be noted that each increment added to the bar increases the rendering
time by 25%.
