SoftPlan Mononpoly House SoftPlan Home Design Software
How can I draw a 1/2 round window on top of another window?
Version(s): 10
On the floor plan, draw the two windows side-by-side. Use Edit Item to adjust the 1/2 round's offset. Make its offset equal to the lower window's offset minus the height of the 1/2 round. NOTE: The offset of a window is measured from the top of the window to the top of the wall. Use Profile mode to check the vertical position of the windows. Dimension and edit dimension lines to align the windows.
Version(s): 11 +
The Add Opening Component feature can be used to create an opening with multiple units. This can be found under File > System Library. In the Library section of the menu, select Openings from the Type field. Highlight the Library you want to add the new opening to. Select the Add button from the Symbol section of the menu. The Add new Opening menu displays allowing you to configure your new opening.
