How do I replace the SoftPlan logo on the System Drawing Borders with my own?
Version(s): 14
The logo shown is an imported image. Simply use Erase > Item Erase and click to remove the SoftPlan logo image.
Bring in your own by going to File > Import > Image. Browse for and select the image. Acceptable file types
are .bmp, .jpg, .tga, .png and .tif. Draw an expanding box in the area where the image is to be placed. If
necessary, the image can be rotated using Edit > Rotate item. Use Move > Adjust item to adjust the logo to
any size. If the Aspect ratio does not need to be maintained when adjusted, use Edit- Edit Item, select the logo
and uncheck the Maintain Proportions option.
