SoftPlan Frequently Asked Questions: Floor Systems
  1. How do I adjust individual joists once the entire set has been drawn in?
  2. How to change the direction of joist on a drawing that have been added using either Ring + Plate + Subfloor + Joist?
  3. I made changes to the floor system in Floor System mode and the elevation offsets of the walls did not change.
  4. How can I hang my floor joists so that the tops of the joists are equal with the top of the sill plate?
  5. How do I add notes to a floor joist layout?
  6. How do I change the orientation of a Joist Poly?
  7. How do I create a brick ledge in a slab?
  8. How do I create an exterior concrete landing?
  9. How do I draw the joist so that they follow my bay window?
  10. When placing joists on the main floor plan how do I locate where the beams are in the basement plan below?
  11. How do I offset the garage slab separately from the basement slab?
  12. On what floor plan should I put my floor systems?
  13. Do I place the sill plate on the foundation or main floor plan?
  14. When I perform a cleanup my joist sets are aligning at the same position rather than staggering. How do I correct this?
  15. When a cleanup is run what determines where the floor system items
  16. In Floor System mode there is an item called a "Ring Joist". What is a ring joist?
  17. How do I add a double Sill Plate?
  18. Is there a way to add drywall to a hole in a floor system or ceiling system?
