Do I have to assign a texture for each cabinet?
Version(s): 10, 11, 12
Yes, but you may expedite the process after editing the first cabinet by using edit | repeat edit and choosing the other cabinets whose texture should be the same.
Version(s): 13 +
No. The cabinet textures can all be changed under one main heading in the Material Assignment. Choose Material > Type – Cabinet. Highlight Cabinet and in the menu below change the textures of the various cabinet items. All cabinet units will inherit the same properties if the textures are applied under the main heading.
