SoftPlan Frequently Asked Questions: Dimensions
  1. When I try to use Auto Dimension
  2. Why does a box sometimes appear in place of my small dimension numbers?
  3. Is there anyway to bypass a wall when stringing dimensions?
  4. How do I change the size of text being used for Opening Dimensions?
  5. Is there a difference between Enlarge Dimension Numbers and changing the size in Character Setup?
  6. Dimension changes are not being accepted. How do I correct this?
  7. When I attempt to dimension between walls
  8. How do I pull dimensions from the corner of the building outline to the property when they are not parallel?
  9. Upon performing a cleanup, my overall dimension is moving so that it overlaps my intermediate dimension strings. How do I prevent this?
  10. Why are my 1/8" increment fractions not displaying or not displaying correctly on screen or when printed?
  11. How do I pull an extension 90 degrees to screen from a corner that is 45 degrees to screen?
  12. How do I pull extensions from a wall to show the length of each panelized section?
  13. How do I get extensions to pull from the outside of a stud?
  14. How do I display Opening sizes
  15. How do I display product codes?
  16. How do I ensure that my opening is 6" from the wall corner?
  17. How do I have dimensions round up to 1/8" accuracy?
  18. How do I move an Opening Dimension?
  19. How do I turn off Opening Dimensions?
  20. How do I turn off Opening sizes
  21. How to dimension to the center of a Post?
  22. I am trying to draw a dimension to a symbol
  23. I reversed my elevation and lost all dimensions?
  24. What if my intermediate dimensions do not add up to what my overall dimension is?
  25. How to move my dimension number off the dimension line?
  26. How do I select a dimension number to move to another place on the dimension string?
  27. Is there a way to remove the wall thickness dimension display?
  28. Where do I set up dimension and extension options?
  29. How do I set up dimension and extension options specific to walls?
  30. Is there an option to change the Dimension and Opening Dimension text sizes in SoftPlan Lite?
  31. Why does SoftPlan dimension to lines?
  32. On Windows XP, why are 1/8" increment fractions not displaying or printing?
  33. When I add, move or adjust an object, SoftPlan adds extensions and dimensions. How can I stop this from occurring?
