Cleanup is not removing portion of walls that bisect with one another? How do I change this?
Draw as you build. Do not continually draw partitions through partitions. One of these walls will need to be broken into two walls so that they may then abut to the main wall. The easiest way to rectify this is to use the Part Erase command. Position your cursor on one side of the wall to be broken and press the From key. Move the cursor to the other side of the wall that this wall bisects and press the To key. The wall will be broken between these two points, and when you perform a Cleanup the intersections will appear correctly.
