Can a JPEG (*.jpg) texture file be imported into SoftPlan?
Yes - JPEG (*.jpg), Bitmap (*.bmp), and Targa (*.tga) texture files can be imported into SoftPlan for use in SoftView. Scan the image at a size of 256 x 256 pixels and a color resolution, or color depth, not greater than 32-bit. Copy the image to an existing folder in the SoftPlan# \ 3D \ Textures \ Bitmap folder. Once there, the texture can be used in SoftView by generating a Rendered or Textured image and applying the texture. See the lesson in the Learning SoftPlan manual, Setting the Texture of a Component in the Materials Menu.
