Can I bring only my system settings from an earlier version of SoftPlan into my current SoftPlan install?
Version(s): 10, 11, 12
SoftPlan will allow you to restore selected parts of a backup created in another copy of SoftPlan (the same version or earlier). Select File > System Options > Archive > Restore > Configuration. Exit SoftPlan and then open SoftPlan again to load the new settings. This will restore your System Option settings without replacing any other current version information.
Version(s): 13 +
SoftPlan will allow you to restore selected parts of a backup created in another copy of SoftPlan (the same version or earlier). Select File > System Options > Archive. Place a check beside Configuration and press Restore. Exit SoftPlan and then open SoftPlan again to load the new settings. This will restore your System Option settings without replacing any other current version information.
