Can AutoCAD open a SoftPlan drawing?
Version(s): 10, 11
No. You must convert your drawing into a DXF format. To do so, open the drawing in SoftPlan, select File > Export >| DXF > and input the name and destination for the file. This will work for both single drawings and multi drawings.
Version(s): 12, 13
No. You must convert your drawing into a DWG or DXF format. To do so, open the drawing in SoftPlan, select File > Export > DWG Version 14 or 2000, DXF Version 14 or 2000 > and input the name and destination for the file. This will work for both single drawings and multi drawings.
