Back | Print
SoftPlan versions prior to Version 11 use the Activator® copy protection key on the computer's
parallel port. The current version of the driver is available below:
| Who should install this update: |
- Version 8 or 9 users upgrading to version
11
Importing drawings from DOS based versions of SoftPlan into version 11
requires that an updated SoftPlan Key Driver be installed. Click on the link below to download
and install the current driver.
Version 10 users upgrading from
Windows® 95, Windows® 98 or Windows® Me to Windows® 2000 or Windows®
XP
If you upgrade your operating system to Windows® 2000 or Windows®
XP after having installed SoftPlan you will also need to upgrade the key driver. Click
on the link below to download and install the current driver. Users upgrading from
Windows® NT do not require this update.
**Version 10 users who are upgrading to Version 11 on the same
computer already have this driver installed and do not require this update. However, if
you install version 11 on a new computer you will require this update on the new
computer.
**Version 11 users who do not have an earlier version of SoftPlan
installed and who are not importing drawings from earlier versions do not require this
update.
Back | Print
