A custom symbol I created is not listing when I generate a report. What should I do to have
it list?
Within SoftList Setup, you must assign a sequence number to the symbol, which will allow the report
to know under which heading to place this item when it is found on the drawing. To do this, select Libraries >
Symbol. Select the Library where the symbol was saved, and in the sequence column assign the appropriate number in
accordance with your Report Style Listing Format.
