Back| Print
SoftPlan 2014 New Features: Walls
Change Wall
Change Wall Highlight
The wall that are going to change type are highlighted making it easier to select the correct wall type to change.
Splash Boards
Wall Trim Splash Boards
Splash Board added to Trim/End Options tab on the Edit Wall dialog.  Automatically places a trim board on the bottom of the outermost wall material.
Trim
Wall Trim and Quoin
Quoins and trim can be added to the same wall via the Wall Trim tab, used when a wall has a mix of exterior materials.
Visible Items
Wall Texture Visibility
Wall Texture added to Visible Items.  Can now be turned off for Electrical Mode and remain on for Drawing Mode.
Wall Definition
Wall Definition Dimension Preview
A preview of the Dimension and Extension locations displays on the Wall Definition dialog.
Back| Print
