Back| Print
SoftPlan 2014 New Features: Site
Site Bearing
If a bearing has a single digit minute or second a preceding zero is added.  Example 181 7' 8" becomes 181 07' 08" to make it easier to read.
Metric Site
Dimension Option Site Object Units added.  Used when the site survey is entered in Metric but the dimension on the site plan need to be in Imperial or vice versa.
Direction of North
Direction of North
Rotate Site only option added when Direction of North changes leaving the floor plan direction alone.
 Fence Dialog Fence Pabel
Automatic Fence command added. Automatically builds fences from selections of boards, rails, panels, gates, posts and post caps.  A wide selection of these items is included and others can imported from external sources.
Flatwork Depths
Default Depth Options are available for all types of flatwork.
@grade Line Type
Line type @grade added.  This places the elevation of the grade as part of the line.
GPX file import added.  Imports GPS data (property lines, shot points) directly into SoftPlan.
Site Options
Site Options
The Site Options are moved to Project Options from Drawing Options and apply to all drawing in the Project.
Retaining Walls
Retaining Walls
Default Wall lists contain retaining walls.
