nBack| Print
SoftPlan 2014 New Features: Openings
Auto Opening Swing
Auto Determine Opening Swing Side option added. See Laying Out Walls
Amarr
Amarr Gararage Doors
Amarrr garage doors added to manufacturers' library.
Andersen
200 series inswing patio door
200 series hinged patio in swing doors added to Andersen manufacturers' library.
Andersen
Andersen A series
A-series double hung windows added to Andersen manufacturers' library.
Center Opening
Center Between 2 Walls
Center Wall Length option added to the Center command.  Places the Opening between two wall that intersect a common wall from opposite sides.
Center Opening
If an Opening is already centered the "center" check box on the Edit Dialog will display as checked when the dialog is opened.
Display
Custom Text Opening Size
Custom Text option added to the display tab.  Allows the opening size to be expressed exactly how the user wishes.
Doors
Round Top Doors
8' Round Top Door library added containing 25 new openings.
Door and Window Dimension Format
Door Dimension Format
Several formats added to the way a door size appears on a floorplan.
Dimension Options Interior vs Exterior Doors
Interior and Exterior Door have separate Door Dimension format listings allowing Interior doors to list as a Width only while Exterior Doors as Width x Height.
Double Action Swing
Double Action Swing
Double Action Swing option added to Doors.
Hardware Offset
Hardware Offset
Option added to move the handles on a door so they sit better on the style of the door.
Header Size
Opening Header Size on Plan
Display option added to allow the opening header size to appear on the plan in drawing mode.
Header Span Tables
Header Span Table
Number of Plys added to Header Span Table.  All openings that use the table update with a change to the table.
Marvin
Clad Casemaster and Wood Casemaster libraries removed.
Mask Option added
Opening Label Mask
Mask option added to Edit removes all items "under" the Opening Label on the screen making the size easier to read.
Opening ID Labels
Opening ID Labels
Option added to configure Opening ID Labels to be Numbers or Letters for windows and doors.
Opening Schedule
Interior Exterior Switchh on Opening Schedule
Interior and Exterior Openings has separate inclusion on the Opening Schedule.
Opening Schedule
Opening Schedule with u-vaules
u-values added.
Panel Doors
Panel Doors
2 Panel and 3 Panel Door libraries added to the Interior Doors.  20 doors total.
Patio Doors
96" tall openings added to libraries.
Pocket Doors
Pocket Door Placement
Placement of Pocket Doors improved in the case where a wall intersects the recessed pocket.
Preview - Hardware added
Opening Hardware Preview
Door Hardware displays on the Opening preview on the Edit dialog.
Sill
Aluminum Sill and Threshold type added.
Site Built Units
Site Built Units
Individual Windows and Doors can be mulled together horizontally or vertically with thickened "mullions" or "transom bars".
Size
When an Opening is resized to fit a space when drawn the size is automatically rounded to the nearest inch or 10mm increment.
Treatments
 Blinds See Laying Out Walls
Horizontal and Vertical Blinds added to Opening Treatment library and can be automatically added and fit to the openings.
Trim
Default setting added. When selected the Opening will always look to the Drawing Options for the trim values. This makes it simple to change the trim all the openings in one spot.
Trim
Trim Profile Options
Profiles added the Opening Trim Systems and Drawing options.
Unit Opening
Unit Opening
Unit Opening command added to the Edit menu.  A quick way to join separate but adjacent openings together into a single unit.
Window
Awning Window Library
Awing Window library added.
Window Position
Window Position
An option to specify the default distance from Bottom of Wall to the Top of the Window is added.  In the example above windows will be placed with their tops at 6'-8" above the floor.
 Back| Print
