Back| Print
SoftPlan 2014 New Features: Decks
Deck Finish Option added
Deck Finish
Finish options allows different materials to be assigned to simlar parts of a deck.
Deck Board Overhang command added
Deck Board Overhang
Command extends the Deck Boards proud of the Deck Ring Joists a set distance.
Sister Deck Joist command added
Command adds a Deck Joist identical in size to the source Deck Joist on the side indicated by the user.
Skirting
Deck with Skirt
Skirting command added to Edit Deck Edge.  This automatically covers the deck edge with a trellis or like material.
Adjust Height To Fit Beam
When a Post is drawn under a Deck Beam the Adjust Height to Fit Beam command is automatically selected.
Parting Board
Deck Edge command added, automatically places decorative board at outer edge of deck.
Ring Joist
Double Ringg Joist
Option Ring Joist Count added.  Easily allows the Ring Joist to be doubled or tripled.
Wall Offset
Walls automatically offset to the top of a deck.  Useful when designing screened porches.
Back| Print
