SoftPlan 2014 New Features: Cabinets
Angled Walls
Angled Wall Cabinet Placement
Placement of Cabinets against angled walls, particularly walls at 1/2 degree increments, improved.
Auto Cabinet
Auto Cabinet
Cabinet Finish and Face Style are synchronized so the upper and lowers look the same when they are added.
Auto Size
Cabinets automatically resize to fit the available space when the selected Cabinet is too large to fit.
AristoKraft
AristoKraft
AristoKraft manufactures library added.
Back Panel
Back Panels on Cabinets
Cabinet Type Back Panel added.
Built-Up Crown
Built-Up Crown Molding
Crown Molding can be built up using multiple trim profiles.  The pieces are automatically aligned in the proper position.
Cabinet Face
Draw Cabinet automatically recalls the last Cabinet Face selected.
Countertops
Countertop Hole
Holes cut in countertops automatically have the edges filled in.
Countertops
Edit Countertop Edges
Freeform countertop edges edit in 3D.
Countertops
Snap will locate on a countertop line.
Crown Molding
Crown
Crown Molding can be automatically added to the Cabinet Run.  Older versions required they be added in Interior Mode.
Doors
Tall Cabinet with Stacked Doors
Doors can be stacked on top of each other on a single cabinet box.
Draw
Cabinet_Draw_menu
The Draw Cabinet menu is no longer stepped making it quicker to select the commands.
Elevate Cabinets
Elevate Cabinet with Backsplash
Countertop Backsplash is added automatically by the Elevate Cabinet command.
End Panels
 Cabinet End Panel Dialog  Cabinets with End Panels
End Panels can be automatically added.
End Panel
End Panels
Cabinet Type End Panel added.  Used to cover the side of refrigerators.
Face Layout
Cabinet 2x1 over 1 x2
Face Layout - 2 drawers side by side over two doors added.
Face Layout
Custom Face Layout
The layout of a Cabinet can be modified directly on the Edit Cabinet dialog box, eliminating the need to go to the cabinet library.
Face Layouts
Cabinet Face Layout defaults added
Cabinet Face Layout defaults added to System and Drawing options.  This allows different type of cabinets to de drawn with different door and draw arrangements.  For example a base cabinet can be set to draw with a drawer over door while a wall cabinet defaults to two doors.
Face Style
Cabinet Face Style Defaults
Default Face Style added to Cabinet Options, at the System and Drawing level.  So all cabinets will be drawn with the desired face style.
False Front
False Front Cabinets
Any cabinet part can has a False selection.  Used to identify non-operating parts such as sink fronts.
Framing Configuration
Cabinet Configuration
Cabinet Options, System and Drawing, have added Framing Configuration.  This allows a user to set the defaults Cabinets to be Framed as Frameless, Inset, Butt, Overlay, or Face Frame.
Fillers
Fill Cabinets automatically resize to fit available space.
Hardware Position
Cabinet Hardware Position
Cabinet hardware is positioned relative to the edge of the cabinet door or drawer resulting in a consistent position as the width of the cabinet change.
Hardware Position
Reverse Hardware Location
Cabinet Face can be reversed Horizontally or Vertically.  This changes the hardware location.
KraftMaid
KraftMaid
KraftMaid cabinet libraries added.
Lighting
Under Cabinet Lighting
Under Cabinet Lighting added.  Light option on the Edit Cabinet dialog automatically adds a light rail.
Manufacturers Library
Manufacturers Library 3D Preview
Cabinets in the manufacturers libraries display a 3D preview for easier selection prior to drawing.
Matching Layout
Search for Cabinet Face
Matching Layout searching added to Select Cabinet dialog.  There are now so many Cabinet Face Layouts that a search mechanism had to be added to make finding specific arrangements more efficient.
Merillat
Merillat
Cabinet lines Classic and Essentials lines added to the Merillat manufacturers' library.
Open Cabinet
Open Cabinet Part
Cabinet Part: Open Cabinet added.
Oven Cabinets
Double Oven Cabinets added to default libraries
Pantry Cabinets
Pantry Cabinet
Tall single drawer pull out cabinet styles added, typically referred to as pantry cabinets.
Pull Out Drawers
Pull Out Drawer
Drawer Type Pull-Out added.   Used for large drawers and tall cabinets.
Preview
Rendered Cabinet Preview
Cabinets display rendered, previous versions used a vector preview.
Preview
Drawing Cabinet
Hardware displays on the Cabinet preview when drawing or editing a cabinet.
Rails and Stiles
Custom Cabinet Rails and Stiles
New custom cabinet face configuration utility has Rails and Stiles as parts that can be added.
This allows user control of the width of the Rails and Stiles.
Show Names
Cabinet Run Show Names
Show Names option added to the Run tab.  When selected the designations for all the cabinet in the run display.
Snap
Cabinet Snap
Cabinets automatically snap back to back making creation of islands easier.
Tiled Backsplash
Tiled Backsplash
Edit Cabinet Accessories tab had a Tiled Backsplash command.  This adds a backsplash of a set height and depth or automatically to the bottom of the wall cabinets.
Toe Kicks
Cabinet Toe Kick Control
Individual control over the appearance of Toe Kicks added.
Wheels
Wheels on Cabinets
Cabinet Legs can be set to wheels.
