SoftPlan 2012 New Features: Notes
@drawing stamp added
Automatically inserts the current file name into a Note.
Auto Label
Auto Label added to the right mouse click.
Auto Label notes are automatically added in UPPERCASE.
Color
Colors  of individual Notes can be changed.
Curved Note command added
The radius is entered as 3 point or SER (start point, end point, radius) or SCL (start point, center, length).
Explode
Exploded Notes maintain their justification and position.
Note dialog is resizable
Open Type Fonts usable in SoftPlan
Outline Mask option added
Blocks out lines and shading behind a note making it easier to read.  The shape of the Mask is controlled by the Outline selection.
 Outline Type Left Bar & Right Bar added
This image shows the Left Bar Note Outline type.
Pointers
Pointers can be drawn either from the note to the object or from the object to the note.
Pointers
Pointers will automatically open the add note dialog if there is not already existing at the end of the pointer.
Replace command added
Search and replace text in existing notes on a drawing.
Right Click Mouse Menu
Click the right mouse button away from all items and a menu containing Notes appears.
Schedules
Floor, Ceiling & Roof Framing Schedules can be set to list Exact or Modular sizes.
Snap
Note Outlines serve as a Snap point.
Stamps command added
Select Stamps from the Note dialog and have access to SoftPlan's information stamps, the @ commands.
Spline Pointer Type added
Triangle Outline type added
