SoftPlan 2012 New Features: Move
Adjust
Items can be adjusted in 3D, previously only solids could be adjusted.
Align to Edge command includes Images
Align Opening Tops added to SoftView modes
In 3D Move displays temporary a color coded axis, assists in determining direction.
Align to Edge command ignores Dimension numbers
Dimension line can still be selected.
Openings
Walls will Move Openings located on intersecting walls that are close to the intersection corner.  In the example above as the vertical wall is moved from A to B the windows on the horizontal walls are moved.
Rotate
Rotate Item added to 3D.
