Back | Print
SoftPlan 2012 New Features:
File
DWG Import improved
SoftPlan AutoCAD® SoftPlan Round-trip
When a .DWG file is created by SoftPlan the drawing data is embedded into the file. When the same file
is brought back into SoftPlan the SoftPlan data remains intact. The SoftPlan data and the AutoCAD®
data co-exist in the same file. This allows a drawing to be sent to an engineer, modified, and then
only the new information be brought back into SoftPlan.
Import AutoCAD® 2010 DWG added
Import Sketchup 8 .SKP added
Import of DWG & DXF includes layers that are turned off
The tuned off layers will automatically be turned off in SoftPlan by default.
Import Metafile added
MiTek®
Export to MiTek® structural engineering software added.
Navigation Window added
The navigation window makes moving between the various parts of a job quick and easy.
Project File added
The project file is a stores and organises all information involved with a job. Drawing workspace arrangements,
floor stack, anything to do with a single house. When a project file is opened the screen will appear as
it did when the job was last closed.
Paper Space / Model Space option added to DWG import
If an incoming AutoCAD® DWG file contains both Paper Space and Model Space definitions a prompt on which to
import will appear.
Save All command added
Located on the default toolbar Save All saves all data associated with the open project.
Save Project Revision command added
Replaces Save Revision command
